Reply To: Internal windscreen surround
Traction Owner’s Club › Forums › Technical › Bodywork & interior › Internal windscreen surround › Reply To: Internal windscreen surround
#26629
    Ron, it unclips to reveal a couple of self tappers.
    It sounds as if the frame has popped out from behind the bodywork.  You may also need to undo the self tapper near the speedo to relocate ut properly.
    Three should be a  U-section rubber seal around the bodywork which keeps things nice and tight and prevents rattles. Check it is there and correctly located
