Reply To: Steering wheel recovering
Traction Owner’s Club › Forums › Technical › Bodywork & interior › Steering wheel recovering › Reply To: Steering wheel recovering
#26735
    Jack,
    It sounds as if yours is not a standard factory fit steering wheel … perhaps you gave a Bluemels wheel?
    The original have a  steel core with a relatively thick “bakelite” type outer.  In time, the outer cracks and, if left unattended, eventually breaks away in thick chunks.  I think this is what Larry is referring to.
    I understand your wheel has a fairly thin outer “plastic” coat which is now disintegrating leaving sharp edges. There are a number of specialists who refurbish these wheels and no doubt forums that will guide you through a diy restoration if that is what you prefer.
    If you type “bluemels steering wheel restoration” into Google the search results could keep you busy for hours.
    B…….
