Reply To: Electronic Ignition Options
#26907
Editor FP
    Thanks for that. I’d be interested to see how you have set up your timing marks. I have found an article online which describes setting something up, so that  a strobe can be used on the pulley and there is another piece on the COCCA website showing timing marks on the bottom of the flywheel, making timing a two man job! (although they do suggest a mirror on a stick). I wonder how many set their timing to 8 degrees static and don’t bother with the extra tweak?
    http://citroen.cappyfabrics.com/principal.html  shows how someone (in the States I think) has used the pulley.
    He is actually doing it on a D series engine, but the principle appears to be applicable to an ID/Perfo
    If it works would also make a good item for FP.
    Thanks again
    Bryan
    • This reply was modified 6 years, 4 months ago by Editor FP.
