Reply To: Electronic Ignition Options
#26962
Editor FP
    Hi all
    Thanks for the comments. I haven’t replied sooner because of the FP deadline.
    You can get the 123 with or without vacuum advance. I will probably persevere with points for the moment and see how things go. A reconditioned /new distributor may be a better solution, certainly better value for money.
    I may also try a new coil. If mine is still the original from whenever the car was converted to negative earth, then it may well not be doing its best in terms of efficiency.
    Philippe, how did you set up your timing marks?
