Reply To: Electronic Ignition Options
#26968
Philippe Allison
    R1000507R1000510
    Sorry about the photo quality. If you look carefully you will see a metal pointer close the the edge of the cam shaft pulley. There is a small saw cut on the edge of the pulley that marks TDC. Not sure if you could doe this without the engine partially stripped as you need to establish TDC exactly. Then you just need a graduated timming light and the calculation mentioned previously as the cam shaft runs at half engine speed.
    All the best Philippe.
