Reply To: Steel bush set flywheel-gear ring 15CV modification
Traction Owner’s Club › Forums › 6 Cylinder › Technical › Steel bush set flywheel-gear ring 15CV modification › Reply To: Steel bush set flywheel-gear ring 15CV modification
#26999
Mark Robinson
    Hi Bernie,
    my engine is out as it needs a full rebuild Having sat for 46 year’s is was seized so no problem wile it’s out I thought I should replace everything that my be a problem later, you did well doing it engine in.
    anyway I think you have answered my question, my flywheel doesn’t have the silent blocks the ones I bought are solid steel see pic C93C104D-4D92-4406-919E-FA06A79FDDCD5765C69A-CE79-4294-B698-623BFA686442
