Reply To: Steel bush set flywheel-gear ring 15CV modification
Traction Owner’s Club Forums 6 Cylinder Technical Steel bush set flywheel-gear ring 15CV modification Reply To: Steel bush set flywheel-gear ring 15CV modification
#27003
    Nark,
    Thanks.  I was aware of your location so that last remark was tongue-in-cheek.  I guess you would probably find a taker in Australia if you advertise them.
    However, if you would not mind micing them up, I would be very grateful to know the three main dimensions, ID, OD and Height.
    All the best and good luck with the rebuild.  Pay attention to the camshaft bearings because they are the oil’s first port of call after the pump.  If they are badly worn and causing a noticeable drop in oil pressure, the pressure at the bottom end will also be reduced and that is likely to lead to premature failure of the mains and/or big ends.
    B……
