Reply To: Steel bush set flywheel-gear ring 15CV modification
Traction Owner’s Club › Forums › 6 Cylinder › Technical › Steel bush set flywheel-gear ring 15CV modification › Reply To: Steel bush set flywheel-gear ring 15CV modification
#27004
Mark Robinson
    Hi Bernie,
    no problem will get the dimensions for you.
    speaking about camshaft I am getting the block dipped so my engine rebuilder has removed all non Ferris metals of it he had a lot of trouble getting the bush that the distributor sits in out it was tight as. Anyway he took the camshaft bearings out and said they are not to good, I don’t think they are available are they? I asked him if someone can reline them and he said we will cross that bridge when we come to it.
    one thing good is the cam is in good nick .
