Reply To: BRAKE PIPE UNION SIZE
Traction Owner’s Club › Forums › Technical › Brakes › BRAKE PIPE UNION SIZE › Reply To: BRAKE PIPE UNION SIZE
#27294
Philip Smith
    Finally all plumbed in. The original male unions were finally found to be M11 x 1.25 and it was not possible to find fittings in this size. 7/16 UNF is very close so a M11 x 1.25 tap was run through two inlets of A 7/16 UNF ‘T’ to connect to the original pipes. Then easy to connect up with the pipe from the servo with a 3/8 UNF adapter. The other pipe from the servo was connected to the original banjo with another adapter. Just need to remove the manifold and drill and tap 5/8 UNF for the vacuum pipe.
    • This reply was modified 6 years, 2 months ago by Philip Smith.
