Reply To: Crankshaft end float mystery
Traction Owner’s Club › Forums › Technical › Engine › Crankshaft end float mystery › Reply To: Crankshaft end float mystery
#27311
Richard Larter
    Hi Phillipe
    I understand that is how it should work but if I fit the sprocket with just the thrust washer there is no clearance and the crankshaft is locked solid and the nut is still not fully tightened hence the mystery. So I wonder if the sprocket is incorrect, is a sprocket thickness of 26mm correct for the Perfo engine?
    Cheers Richard
