Reply To: Crankshaft end float mystery
Traction Owner’s Club › Forums › Technical › Engine › Crankshaft end float mystery › Reply To: Crankshaft end float mystery
#27327
    Richard,
    Like Phil, I cannot envisage what is causing your problem because end float adjustment  is not st all dependent on the timing sprocket thickness as the video clearly shows
    Could there be something else blocking the shaft and/or it’s various components.
    Please can you post pictures of all your bits loose and then assembled in the block?
    Ta,
    B…
