Reply To: Radiator Thermostat
Traction Owner’s Club Forums Technical Other Radiator Thermostat Reply To: Radiator Thermostat
#27938
Nigel Watling
    you can get thermostats that fit into the top hose, I also drilled and tapped the water pump housing  to take a 1/2″ hose adaptor which feeds the cab heater, with a stat fitted it speeds up the heater output as its not circulating around a cold radiator until stat opens.
    Nigel
    • This reply was modified 5 years, 7 months ago by Nigel Watling.
