Reply To: Where to put an oil gauge sensor ?
Traction Owner’s Club Forums Technical Other Where to put an oil gauge sensor ? Reply To: Where to put an oil gauge sensor ?
#28074
    I assume you own a French car. At the rear of the engine on the carb side down low you will see a plug facing to the rear- that is the main oil gallery. Jose Franssen sells a kit to install an oil pressure gauge with a plug that is set up for the proper fitting of a line at that point.
