Traction Owner’s Club › Forums › Technical › Gearbox & drive shafts › Slipping out of gear › Reply To: Slipping out of gear
Thank you all for your advice, Larry can you explain to me what you mean by the nut on the lower shaft , is this behind the outer cover plate?
