Reply To: Slipping out of gear
Traction Owner’s Club › Forums › Technical › Gearbox & drive shafts › Slipping out of gear › Reply To: Slipping out of gear
#28097
    It is the lower shaft in the gearbox that is accessed by removing the lower plate that is held on by 5 bolts. Behind it is the nut that is held in place with a tab washer. it is possible that the nut has loosened, that happened to me once. Once I tightened it, it did not jump out of gear.
