Reply To: Clutch Adjustment
Traction Owner’s Club Forums Technical Gearbox & drive shafts Clutch Adjustment Reply To: Clutch Adjustment
#28130
Alain Sauvage
    I was keen to have ago at toggle adjustment but the advice line said I would be better off taking it to a clutch specialist.  I have a 1955 11C with 4 cyclinder performa engine, the cluch friction plate and flywheel has been rectified, and reassembled with fresh springs, spacer washers, toggle bolts washers and nuts. Is there any specific information I need to give to the clutch centre or will they just know what to set it at?  Thanks regards Alain
