Reply To: Carburettor overflow
Traction Owner’s Club Forums Technical Other Carburettor overflow Reply To: Carburettor overflow
#28398
    Joseph,
    It is not uncommon for a little fuel to drain out of the overflow – especially if the throttle has been depressed after the engine has stopped running – but your “issues forth” suggests more than that.
    I wonder if either the carb float level is set too high or the fuel valve is sticking, allowing fuel to escape while the system remains pressurised between the carb and pump.  If you prime the fuel pump manually (without the engine running) either of those faults is likely to cause fuel to overflow from the drain pipe once the carb fills up – even on a cold engine.
    And a word of caution …. It may be obvious but there should be a set in the overflow pipe to ensure it does not dump fuel directly onto the starter motor.
