Reply To: Clutch Adjustment
Traction Owner’s Club Forums Technical Gearbox & drive shafts Clutch Adjustment Reply To: Clutch Adjustment
#28415
Alain Sauvage
    Thank you Chris and Bernie. I am starting to reassemble but have a question. When the flywheel was removed I noted it was secured in place with 6 15mm bolts no lock plate or lock washers to be seen. The parts manual has a lock plate in the pictures, is this required for the reassembly in this 1955 ID 19-P?
    Thanks.
