Reply To: A turn signal problem
Traction Owner’s Club Forums Technical Electrics A turn signal problem Reply To: A turn signal problem
#28803
    Thanks Bernie- the unit does flash properly when turning to the left, it ticks and then shuts off but the dash indicator light does not flash when turning left. Turning it to the right, it ticks and shuts off but no power is coming out of the switch. The dash light does flash when turning right so maybe I can sort it out.  Over here I can get a lever switch that looks good but with that I will need a 6 volt flasher. I’ve done that on my 54 11B and it works well but no automatic shut-off. I’ll take a crack at it later today.
