Traction Owner’s Club › Forums › Technical › Gearbox & drive shafts › Rubber draft excluder on doors › Reply To: Rubber draft excluder on doors
Open the channel enough to make the job “easy”. Use a wooden or plastic tool to minimise damage to paint.
When the rubber is in place return the channel to its original shape. Put a wooden block against the channel and tap that carefully.
wit
