Reply To: Warerpump lubrication nipple
Traction Owner’s Club › Forums › 6 Cylinder › Technical › Warerpump lubrication nipple › Reply To: Warerpump lubrication nipple
#29846
    Kevin
    The oiler is just a push fit and will normally pull or lever out fairly easily.  If it is hard to shift, a stud extractor (tapered type with a left hand spiral) will almost certainly remove it.  I would not recommend drilling to avoid debris in the oil way.
