Traction Owner’s Club Forums Technical Engine Starting Problem 1952 11BL Reply To: Starting Problem 1952 11BL
#29855
Richard Larter
    Hi Mike
    Two thoughts. You could try squirting some oil down the plug holes in case the bores have dried out with sitting and compression is not being achieved. If that doesn’t work try Easy Start (Start yer Bastard) and if it fires then the problem is not electrical.
    Hope this helps
    Cheers Richard
