Traction Owner’s Club Forums Technical Engine Starting Problem 1952 11BL Reply To: Starting Problem 1952 11BL
#29966
    I had this problem while trying to start my car this spring after sitting all winter.  The needle valve in the carb was stuck closed so I smacked the carb with a rubber hammer and all was well. This was after pumping the priming lever about 100 times with no results, then I recalled the same thing happened last spring. Some gentle persuasion and that was it.
    • This reply was modified 4 years, 2 months ago by Larry Lewis.
