Traction Owner’s Club › Forums › Technical › Engine › Starting Problem 1952 11BL › Reply To: Starting Problem 1952 11BL
Mike,
you say you have compression. Also test for suction by removing the air filter and holding a hand over the top of the carb as the starter is operated.
If no reasonable suction can be detected, refer to earlier message re. putting oil into the bores to help the rings to seal.
Assuming you do have adequate suction, clean and dry – and if possible warm – the plugs then refit them and pour about 10ml of good fuel directly down the carb throat while the engine is turning over on the starter. If that fails to make the engine fire, repeat without petrol but squirt SYB directly into the carb instead.
Should the above fail to produce even a cough, I would suspect a problem with the spark – despite your previous efforts in that area.
I would therefore go back to the ignition system to confirm timing and check operation of points, condition of rotor, cables, condenser, dizzy cap, etc……..
Good luck,
