Reply To: Still learning engine oil recommendations
Traction Owner’s Club Forums Technical Engine Still learning engine oil recommendations Reply To: Still learning engine oil recommendations
#30018
Richard Larter
    Be careful, straight grade oils do not contain detergent and sludge builds up in the sump and the internal surfaces of the engine which is normal. If multigrade oils are used which contain detergents then this sludge will go back into circulation which is a problem with the Citroen engine which does not have an oil filter and increased wear will occur.
    Cheers
    Richard
