Reply To: Metallic chafing noise from the front end
Traction Owner’s Club › Forums › Technical › Brakes › Metallic chafing noise from the front end › Reply To: Metallic chafing noise from the front end
#30104
    Jack up using jacking point and check rotation on full lock.
    If no sign of anything untoward and, if wheel bearings are fine, suggest remove drum and look for any indication of contact between drum and backplate assembly, i.e. “polished” area or similar.
