Reply To: Valve springs
Traction Owner’s Club Forums Technical Engine Valve springs Reply To: Valve springs
#31865
Richard Larter
    You could use some string. If you feed some string into the plug hole with that piston at the bottom of its stroke then when sufficient string is in place the piston can be rotated to force the string against the valves and hold them in place. You could use compressed air but I put my trust in string!
    Cheers
    Richard
