Reply To: Valve springs
Traction Owner’s Club Forums Technical Engine Valve springs Reply To: Valve springs
#31868
Roger Grix
    For general information:
    The springs that have failed were supplied by CAS in 2016.
    Andrew has not fitted new valve springs on any other engines so, if he has worked on your car, you don’t have to worry.
    If you have fitted some, it may be worth a check.
    Roger_G
