Reply To: Big 6 Drive shaft nuts
Traction Owner’s Club › Forums › 6 Cylinder › Technical › Big 6 Drive shaft nuts › Reply To: Big 6 Drive shaft nuts
#32222
    Mark,
    I guess such nuts will be available but probably not cheap and will ideally require replacement every time they are removed.
    I would rather put my faith in a castellated nut and split pin rather than a nylon insert any day.  Therefore, were I in your shoes, I would simply drill the necessary holes, either before fitting (using an old shaft as a pattern), or in situ once the nuts have been correctly tightened.
    B……
    • This reply was modified 3 years, 7 months ago by Bernie. Reason: Typos
