Reply To: jerky drive
Traction Owner’s Club Forums 6 Cylinder Technical jerky drive Reply To: jerky drive
#33673
Bob Cross
    Hi Bernie
    Thank you for your prompt reply to my post. I had suspected that the next stage is to open up the gearbox and see what is revealed. By the way, do you know what would be the
    ‘normal’ play would be at the tyre as I have described? About the Bibax shafts:-
    I don’t know about the comparison between Bibax-fitted and non-Bibax fitted shafts . I had assumed that the advantage of Bibax shafts would have only been apparent at the the extreme end of the performance range -hard cornering and acceleration , braking, rough terrain. I drive quite sedately so I have noticed no difference.
    When we fitted the new non-Bibax shafts, initially we had hoped to slide them in without dismantling the swivels, but in the end we did have to take apart the top swivel and with difficulty got the shaft fitted.
    Bob
