Reply To: Diaphragm clutch
Traction Owner’s Club Forums 6 Cylinder Technical Diaphragm clutch Reply To: Diaphragm clutch
#36479
    Larry,
    I have a diaphragm in my 15/6.  These are the main elements …
    https://www.dropbox.com/scl/fo/lbngaurj6g5w6oic9f45b/AAexxx9NHaFd2Q-4DlvBXwY?rlkey=m0puitvlacca1ayo99y3b6jf7&st=sb9345bj&dl=0
    However, it did require a different flywheel to replace the original bi-plate unit.  Mine is actually a newly made flywheel which came from a chap who had it “spare” and unwanted, on the shelf.  Unfortunately, I don’t know how it compares with a later, original, single disc flywheel.
    In honesty, I don’t think it makes the clutch operation much lighter but it does haveo a ball thrust race and that is definitely better for wear than the carbon original.
