Traction Owner’s Club › Forums › Technical › Suspension & steering › Tyres › Reply To: Tyres
I’ve been running my tyres at 25 – 27psi. Can’t remember why. I keep the front and rear the same.
3 – digit dates codes have not been used since 2000. So yes – ancient.
Rim band – is rim tape used to protect the inner tube from anything on the surface of the rim that would damage the tube, which would typically mean spoke ends. I spoke to Longstone about whether they were useful to protect the tube against the rivet heads of the traction wheel. He said “absolutely not required, never seen any tubes damaged by the wheel rim”.
Hard to know what to suggest as a substitute for axle stands – big blocks of solid wood if you have sufficient. Bricks and breezeblocks can crumble and should only be used when stealing the wheels off someone else’s car. Axle stands are cheap compared to a set of tyres and it is useful to have a set of 4.
I have Blockleys on my DS and they are fine but chose Michelins for the Traction, mainly for the look.
