Reply To: Diaphragm clutch
Traction Owner’s Club Forums 6 Cylinder Technical Diaphragm clutch Reply To: Diaphragm clutch
#36617
Steven Wright
    Hi Bernie,
    I have raised it on the CitroenTA@groups.io forum and got a very quick response from Mark Harding. The response is directly quoted below: –
    Hi steve,
    I always use the sprung 215 mm dia plate from the 11cv. You often need to rotate the flywheel as you ease in the cover plate.  You can make little hold down clips to hold the three operating fingers against the springs. They are shown in the manual.</p>
    Best regards Mark
    The next one I need to resolve is the ball thrust race as this would seem to be the better solution over and above the ” Carbon Version”.
    Steve W
    • This reply was modified 1 year, 11 months ago by Steven Wright.
