Reply To: Dynamo not charging battery. 1955 11BL
Traction Owner’s Club › Forums › Technical › Electrics › Dynamo not charging battery. 1955 11BL › Reply To: Dynamo not charging battery. 1955 11BL
#37019
    Ian,
    Extracting the instrument cluster is less daunting than it sounds.  Yes, you do have to remove half the windscreen trim but it is a relatively simple job and Chris has pretty well explained the method …. even though he has never done it!
    Plrase contact me if you run into a problem – I’m about 10 minutes away from you.
