Reply To: Inlet manifold
Traction Owner’s Club › Forums › Technical › Engine › Inlet manifold › Reply To: Inlet manifold
#37283
John White
    Apologies folks.
    Got side tracked just as about to type!
    Recently had a rough running engine but have eventually hopefully tracked down the problem.
    Never had the original inlet manifold drain tube but just a bolt screwed in to it.Turns out this had slackened off and I can only assume was drawing too much air. However was a good opportunity to drill a half mm hole through the bolt  and loctite the bolt back in.
    Also gave the Solex a strip down and all appears good again.
