Reply To: Dynamo not charging battery. 1955 11BL
Traction Owner’s Club › Forums › Technical › Electrics › Dynamo not charging battery. 1955 11BL › Reply To: Dynamo not charging battery. 1955 11BL
#37397
Glen Winkfield
    I have the same problem Chris. The regulator is not switching over to the dynamo once the engine is running.  You imply that it might not be a regulator fault as I had supposed. If the ammeter is not registering is it not as likely to be the fault of the regulator as a wiring problem?  Is there a way to test the regulator before dismantling the dashboard?
