Reply To: 1950 11BL dashboard controls
Traction Owner’s Club Forums Technical Bodywork & interior 1950 11BL dashboard controls Reply To: 1950 11BL dashboard controls
#38019
    That “mystery light” is not original but do check to see if it’s connected to anything. You may want to wire it to the high beam circuit so you have an indicator. To remove the knob from the spark advance, you need to remove it from the dashboard and you will see how it comes apart.  Installing a push button for the starter is fairly common, I have that on one of mine. I assume that the push button is connected to a relay?
