Reply To: Possible Fuel vapour from solex35 carb
Traction Owner’s Club › Forums › Technical › Engine › Possible Fuel vapour from solex35 carb › Reply To: Possible Fuel vapour from solex35 carb
#38339
    <p style=”text-align: left;”>Is it just vapour or is it liquid fuel, and if liquid, is it coming from the copper manifold drain pipe or from the carb itself?</p>
    If the engine has been run hot without the air filter, you will possibly see a little vapour when it stops.
    If it is liquid fuel from some other part of  the carb it does not sound normal.
