1951 Slough Built Light 15
Traction Owner’s Club Forums Technical Bodywork & interior 1951 Slough Built Light 15
  • This topic has 5 replies, 4 voices, and was last updated 6 years ago by Patrick Russell-Jones.
Viewing 6 posts - 1 through 6 (of 6 total)
  • #26226
    Nigel Watling
      Hi,  struggling to find outer door handle replacements for my Light 15, I have spoken to Chris at TOC Spares and he tells me the one he carry have the wrong hole centers and so are not a good fit.
      Does anybody know of an alternative from another make that used the same handle?
      Nigel
      #26227
      Roger Grix
        Hi Nigel,
        This site might be worth a look. I have no idea if they have what you want or what sort of quality they are but they look like they might have something.
        https://www.europaspares.com/exterior-parts/handles-locks.html
        Otherwise, there will be some in someone’s garage. Have you tried John Gillard?
        R
        #26235
        Norman Anderson
          Hi Nigel, if you’re completely stumped, why not fit the French handles? I got a set from Franssen for my 1953 Slough Light 15. They are such an elegant design compared to the English handles https://www.citroen-traction-avant.com/en/shop/article/215=!002/Outside_door_handle_rear_left_chrome
          #26244
            Hi Nigel
            I have had these fitted on mine https://www.vintagecarparts.co.uk/products/701-container-exterior-door-handle-14
            with 44mm escutcheon. Round headed screws can be used at an angle to camouflage the different spacing.
            Patrick
            #26264
            Nigel Watling
              Thank you for all the suggestions, some I have seen but some to follow up.
              Patrick, I have considered these handles but with a 38mm hole center rather than the 44mm centers as my fixing hole centers are 39mm, any thoughts ?
              Nigel
              #26319
                Nigel,
                Mine were done using 44cm centres and redrilling the back plate to fit.
                Patrick
