Battery electrolyte filler cap
Traction Owner’s Club Forums For sale & wanted. Suppliers Wanted Battery electrolyte filler cap
  • #28370
      HEEEEEELP!
      I have lost one of the three threaded plastic breather caps from my Traction battery….
      20210526_080415
      Does anybody have a dead battery with a suitable cap they are prepared to part with, please?
      The thread is 26mm dia. x 2.5mm pitch.
      I have tried several local battery suppliers but they only have “modern” batteries in their scrap piles.  New replacements caps are available online ….. but only from the States and they incur silly carriage costs (a new battery would be cheaper).
      Thanks in advance,
      B…….
      #28384
      Tony Buxton
        Unfortunately I took several dead old tractor batteries to the scrappy a couple of weeks ago Bernie. If you don’t have a lorry or agricultural scrap yard near you I could look in at our local scrappy next week. I don’t think the 12v heavy duty batteries have such shallow caps as the one in your photo but perhaps you could use a full set for the look.
        Good luck, T
        #28385
          Tony,
          Thanks anyway.  Of course I shall be happy to replace all 3 caps to make them match but, in honesty, I am more concerned to keep the cell covered and breathing than I am about the caps all looking the same.  At the moment I have a piece of duct tape covering it with just a small pin-prick hole for gas relief so, even odd caps would be an improvement.
          B…
          #28386
          John
          Keymaster
            Hi Bernie
            I have a dead battery in the garage. Caps are a different style but same size. I can get the 3 in the post to you later this week.
            John
            #28391
              John,
              Thank you very much.  How many beers will owe you?
              #28399
              Tony Buxton
                It looks as if John has solved your cap problem Bernie, but I found these caps at the scrap yard if you still need them. The size seems fairly universal so it was a good heads up to have some spare for old batteries such as we use. I also have some in yellow good perhaps pour encourager les yeux.
                Cheers,  T
                0
                #28414
                  John,
                  Caps received and fitted – absolutely perfect.
                  Thank you – blank cheque in the post as requested.
                  P.s. … I now have 2 spares if anybody has a similar problem.
