Bell housing to engine retaining bolts
Traction Owner’s Club Forums Forum Archive Traction Owners Club Forum Help Wanted Bell housing to engine retaining bolts
  • #4329
      I cannot get a spanner to fit correctly on the small bolts connecting the bell housing to the engine block.
      The bolts have a major diameter of 6.8mm with a pitch of 1mm (about 25 or 26 to the inch). The spanner is somewhere between 11mm and 12 mm, the 12mm is lose and will not grip a tight bolt. The nearest I can find is a cycle thread but can it be that!!
      Can anybody tell me the correct bolt and thread type for this application.
      #5879
        Found out the information. 7mm dia bolts is the info I wanted
        #5880
          There are a lot of 7mm fittings on the Traction, battery retaining bolts, air filter to inlet manifold etc. etc.
