Boot hinge
  • #23916
    Non Member
      I have a Light 15 , small boot .
      We want to replace the pins in the boot hinges. Would someone be able to tell me / send photos of original pins. My car had a modified bolt as the pin.
      Cheers Simon
      unlimitedliability@hotmail.com   For any photos.
      #23922
      Paul Barnard
        Hi Simon
        I’ll see if I can get a pic in the morning
        Cheers
        Paul
        #23926
        Alistair
          Not the best pics but mine seem to be a blind headed, threaded bolt with no nut. From a 1939 Light 12…
          IMG_0838 (002)IMG_0839 (002)
          #23932
          Paul Barnard
            Hi Simon
            Here are my hinges – my car is a 1950 French built 11BL
            hinge pin3hinge pin2
            You can see that on my car they are a dome headed pin and the ends are just hammered over like a rivet. They are 60mm long and 7mm in diameter and as such they are identical to the door hinge pins.
            hinge pins
            Chris has these available from our vast selection of club spares
            hinge pins_003
            If yours have had bolts put in I would suggest that you go for the oversize pins.
            Cheers
            Paul
            #23937
            Non Member
              Thank you both for the info
