Boot hinge pin removal
Traction Owner’s Club Forums Technical Bodywork & interior Boot hinge pin removal
  • #27545
    Peter Kerr
      I successfully removed the hinge pins from the doors and have those off the body.
      Moving on to the boot lid. I’ve removed the small clips on the end of the pins but they don’t seem to be coming out. So far I’ve been using penetrating oil and a hammer.
      Am I missing anything, or do I just need a bigger hammer?
      Thank you
      Peter
      1951 BL. French.
      #27546
        Peter,
        If they are that tight I would suggest unbolting the hinge from either the boot lid or the frame ……. having again, applied plenty of penetrating fluid first.
        #27552
        Peter Kerr
          Thanks Bernie,
          I’ll take that approach. Those bolts are rusted/crumbling so I should remove them anyway.
          Peter
