Carb heat shield?
  • #4508
      Just taken the carb off to send it off for overhaul.
      Noticed there is no carb heat shield. Presume it should have one? If for no other reason, if the carb is leaking petrol it will end up on the exhaust manifold?
      Found one on fleabay, which I can pick up next time I’m in the States, guess this is what’s needed? Thanks for the impending advice!
      http://www.ebay.co.uk/itm/Citron-7CV-11CV-TRACTION-AVANT-USED-CARBURETOR-BASE-HEAT-SHIELD-ORIGINAL-PART-/142026108058
      #7195
        CAS and Fransens have them pretty cheap and brand new unlike the one from the USA. The idea is it keeps some of the heat away from the float chamber which helps stop fuel evaporating. Yes it does also help if any fuel leaks but to be honest by that stage I imagine the flames would let you know there was a leak. Be aware that the original heatshields are made with asbestos. Also watch out as there are two types to my knowledge. Edited to add yes two types of asbestos but also two types of heat shield.
        #7196
          Thanks Baz, of course asbestos. We don’t like that!
