Champion H10C spark plugs
Traction Owner’s Club Forums Technical Electrics Champion H10C spark plugs
  • This topic has 2 replies, 2 voices, and was last updated 3 years ago by Dave Thornley.
  • #29956
    Dave Thornley
      Got a set of these a while back off the club and today decided to fit them. Problem is current plugs, Champion H10C, have a removable terminal so that the lead clips onto the threaded portion. when terminal unscrewed off.  The H10C from the club are the solid type with no removable portion. So obviously I cannot use these plugs. Surely others must have had this problem. Mind you I cannot find a picture of an H10C with the screw bit removed. Am a bit confused.
      #29957
      Richard Larter
        This is a problem. I have 2 sets of plug caps and use to suit which ever plugs.
        #29958
        Dave Thornley
          Is a strange affair. I reckon that the solid ends of the H10Cs have been unscrewed out completely from the porcelain section and some other screwed ends used to replace them.
