Having decided to fit a temp guage and oil pressure gauge I thought the easiest method of accesssing the water would be to fit one of the aluminium thingies that you
fit into the water hose. I got one but the tap for the sensor to screw into is a 1/8NTP thread and the one on the gauge is a 5/8 UNF, slightly bigger!
There is enough metal on the thingy to drill and tap to 5/8 UNF just. As an alternative I could drill the water pump housing. Question is where is the best place, or worst place to
drill it. The actual sensor bulb is quite large. Any suggestions ?
Attached is a photo of the thingy.
This topic was modified 1 year, 1 month ago by Dave Thornley.
You must be
logged in to view attached files.
