Electric Fans
  • #4280
      I am looking at putting in an electric fan on the front of the radiator.
      Will this conflict with the original mechanical fan – i.e. does the original fan suck or blow (never having mine actually work yet) and would putting on an additional fan which I presume will blow air onto the front of the radiator mess up the air flow, cooling dynamics of the system.
      If anyone has done this can they post a photo of the fitting and also where they install the thermostat.
      Thank you
      Ian
      #5579
        The original must suck air otherwise air would net get through the radiator.
        In answer to where to fit the thermostat I have fitted a Kenlowe 2 speed electric fan to my Cabriolet. They make both 6 volt and 12 volt versions. The sensor fits inside the top hose, between the hose and the radiator inlet. They do come with a manual override and I fitted one myself because I only have the electric fan.
        The rest of the controls and relays I have fitted in the jambonneau. See photos attached.
        #5580
          So the thermostat is tiny then. I have seen the lager units where you cut the top hose and place in the T adapter.
          Do you also have a temperature gauge in the car – I am looking at fitting this too but did not want a mass of probes hanging out my hose 😉
          #5581
            The electric fan is if course a blower fan as it is mounted on the front of the radiator. I have an analogue temperature gauge. I did not like the 70’s style rocker switch supplied for the 2nd speed so bought one of their 24 volt round rocker switches which I think looks better.
