Electric fuel pumps
  • #4647
      Good morning all,
      It would appear that my mechanical fuel pump is becoming less effective with the progress of good old farther time.l was therefore considering either a straight replacement and/or and electric fuel pump.
      I would appreciate your views, opinions and knowledge on this subject. Is it a good idea, pro’s and con’s, what is the best type of pump, what needs to be bore in mind when fitting and where best to source a pump.
      As always I look forward to your reply’s 😉
      #7785
        John Gillard or Chris from TOC will Supply you with a new mechanical pump, definitely would not recommend a secondhand pump, any type that John recommends would do and there not that expensive.
        Johns number is 07763144598.
        Hope this helps.
        Regards
        Davy
        #7786
          Hi Leclerc,
          I think you are running 6 volts which will limit your choices a bit.
          I was looking at a Light 15 the other day which has an SU pump – not sure which one but they seem to be about £80.
          Examples here:
          http://www.holden.co.uk/displayProducts.asp?sg=2&pgCode=015&sgName=Hardware&pgName=Fuel+Pumps&agCode=0100&agName=SU+Fuel+Pumps
          On the other hand Chris offers repair kits for the mechanical pump for £10 – 20 depending on what you have. A mechanical pump in good nick should do the job and the repair kit covers the parts that fail.
            Jose Franssen has a new production pump for not a lot of money. I have one on my 11Bl and it works well.
            #7788
              I have an SU electric pump mounted next to the fuel tank on my Light 15. Definitely a boon when starting after the car has been idle for a week or so, since it primes the carburettor without having to crank the engine, so it is easier on the battery. 6volt versions are available. The SU has a pressure sensor built in and does not pump when the needle valve is closed by the float and is also fairly tolerant of contamination such as small flakes of rust. Other types will need a pre-filter. Some electric pumps , such as the Facet type, just pump continuously, in a stalled condition, whether they can deliver the fuel or not, and can be noisy. You also need to review the output pressure of pumps like this, which may need a separate pressure regulator to avoid flooding the carburettor at low revs. This isn’t necessary with the SU.
              Electric pumps are also either pushers or pullers. Pushers are mounted by the fuel tank, pullers can be mounted in the engine bay, rather like a Morris 1000.
              With an electric pump, you can also immobilise the car with a discreet switch somewhere in the circuit.
              If you go electric make sure that you use resilient mounts to avoid the noise that some pumps can make, transmitting into the car.
              Burlen are the people if you want to go down the SU route.
              https://burlen.co.uk/
