fitting alternator kit from spares shop
Traction Owner’s Club Forums Technical Electrics fitting alternator kit from spares shop
  • #24788
    Roger Arnold
      Hi has anyone fitted the alternator kit from the club spares shop?
      if so any problems with this kit has it got every thing to do the job with
      thanks
      #24789
      Norman Anderson
        Just fitted a Stealth Dynamator £144.95, including VAT and delivery.
        Beautifully made 45amp alternator, looks just like a Lucas C39 / C40, and fitting it was a piece of cake https://www.ebay.co.uk/itm/331945146035
        • This reply was modified 6 years, 7 months ago by Norman Anderson.
        #29910
        Alain Sauvage
          For the club alternator converter to wire in a alt warning/starter lamp on a late french car is there a particular pole of the ignition switch that it should connect to?
          #33731
          Alain Sauvage
            Club alternator now wired in and charging. Connect the B+ of the alternator so that it will connect to the three wire pole of the amp meter. Run a wire from the D+ of the  alternator and connect to a standard bulb warning 2 – 5w lamp in parallel with a resistor (I used a 10 watt 30 ohm wire wound aluminium body resistor from amazon) attach this to the ignition switch. I scraped and filed the alternator mounting to the engine to ensure there is ability to ground through the engine. The above is in a french car, I am no electrician but it all works now.
            #37107
            Peter Hipkiss
              Good Morning Norman
              A somewhat late enquiry regarding your Stealth alternator: may I ask what battery you had on the car – I’d always been told that the alternator should have a greater amps output than the battery capacity…. Thanks.
