French distributor clamp
Traction Owner’s Club Forums Technical Engine French distributor clamp
  • #24673
    Norman Anderson
      More help please….
      Fitting a 123 dizzy to my Slough L15. The UK clamp doesn’t fit as it’s too big. 123 aren’t interested, they say get a French clamp.
      Does anyone have a French clamp out there? The shaft diameter is approx 27mm.
      John Gillard seems to be snowed under. This one was very kindly given to me by Mark from Devon, but it’s a bit too distorted.
      802XUD_Lo_Res55
      #24677
        Who’s a lucky boy then  …….
        P4040082
        P4040083
        Could post or else you are welcome to collect from Wellingborough if you want a run out.
        Make me a stupid offer and I shall almost certainly be stupid enough to accept
        B………………………….
        #24678
        Norman Anderson
          Bernie, you are a gent. Thank you so much!
          I don’t know, £15 plus postage?!
          If that’s ok:
          Norman Anderson
          The Orchard, Queens Close, Harston, Cambridge, CB22 7QW
          Please include your bank details, or if you don’t like doing that, your address, so that I can drop a cheque in the mail!
          #24682
            Norman,
            Too much …. I said “stupid” – say £10 plus postrage – shall attempt to send today, if not tomorrow at latest.
            B……
            #24683
            Norman Anderson
              Very gracious of you. I didn’t want to risk being impudent!
              I’ll get back to Google, trying to find out where the No. 1 cylinder is, and how to find this mysterious 6mm hole in the flywheel!
              Getting very exited about firing up the engine after a protracted four year restoration!
              #24693
                The mystery hole is through a boss in the bell housing casting – just below where the camshft passes through.
                Pin HoleIt may be hidden by the fuel pump heat shield (if you have one).
                B………………
